LabVIEW Jake AI
Can I generate code by using jake AI using free version in latest Update?.
(1,982 Views)
Jake cannot generate code, but I've found it to be pretty useful.
NI are working on an AI that can generate code, it is called NIGEL. NIGEL is expected to release this year: https://www.ni.com/en/shop/software-portfolio/software-roadmaps.html#labview
(1,855 Views)
Now that Nigel has been released for a couple of months, have you had time to test drive it?  Knowing you have experience using Jake, can you compare the two?  I know Nigel has a 6-12 month plan to include code generation, have you heard anything from JKI on a plan for Jake to do the same?
(1,548 Views)
