LabVIEW MODBUS16 communication
Does anyone have a good example of how to communicate with the following protocol via RS232 MODBUS16 CRC?
  • Baud Rate: 19,200
  • Data bits: 8 Bits
  • Parity: None
  • Stop Bit: 1
  • CRC: MODBUS16
Message 1 of 8
(4,436 Views)
Modbus16 - I don't know about such a protocol.
There are several LabVIEW libraries available for download that are capable of
Modbus ASCII, Modbus RTU and Modbus TCP.
All of these include examples.
Regards, Jens
Kudos are welcome...
Message 2 of 8
(4,403 Views)
Thanks for the information.  Where can I find the libraries?
Message 3 of 8
(4,381 Views)
Easiest way is the VI Package Manager https://vipm.jki.net/
If you don't use that just do a search for "LabVIEW Modbus".
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 4 of 8
(4,368 Views)
I was able to install the libraries, however, how can I send the following command to a device?  None of the functions have a data send input.
0xA5 0x05 0x0D CRC
Message 5 of 8
(4,345 Views)
What does that command mean?
Did you look at the examples for Modbus that are installed with the libraries such as the Master?
Message 6 of 8
(4,337 Views)
There's like 3 or 4 MODBUS libraries, so without you telling us which one you actually got, it's difficult to help.
As a general note, to send what you're trying to send, you're probably looking for something called "Modbus write multiple holding registers.vi", and you need to convert those 3 things you're trying to write from hex into 16-bit unsigned integers.  So the "data send input" might be labeled something like "Registers", and would be an array of U16.
Message 7 of 8
(4,333 Views)
Thanks to everyone for all the help.  I was able to get it to work:)
Message 8 of 8
(4,293 Views)
