LabVIEW MPEG Video Encoding
Any suggestions on LabVIEW tools to compress 3 video streams from standard
PAL cameras, simultaneously, for periods up to 5 hours? Ideally using IMAQ
1409 board. S/W plug-in would be great, but would also consider CompactPCI
frame grabber with hardware compression, and appropriate LV drivers, for PXI
based system. Thanks in advance for any suggestions.
Tim
(3,364 Views)
You can also visit www.imagemill-tech.com for more solutions.
Chris
(3,364 Views)
Thanks Chris,
Any other options that compress the data, as much of the anticipated image
is static, and so storing full, uncompressed, frames, as in the Imagemill,
will be hugely wastefull.
Tim
"cld" wrote in message
news:506500000005000000A0B00000-1031838699000@exchange.ni.com...
> Chris
(3,364 Views)
