LabVIEW: Memory or data structure corrupt.
Accepted by topic author vgezer
Take the hex string and using the conversion function turn that into an array of U8s. Wire that array to the function to format a number into a 2-digit hex-represented string. The result is an array of strings. Wire that array to the input of a string concatenator. The output will be all the elements appended into one long string.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 15
(3,202 Views)
Yes, now it is working!! Thank you 🙂
Message 12 of 15
(3,198 Views)
One more thing to be added to my VI is adding leading zeros for example:
When I write: 000A 3500 05DC
The result becomes: 0A3505DC
Is there any easy way to add these zeros for better display?
Thank you...
Message 13 of 15
(3,196 Views)
Yes: set the Width input of the string-to-hexadecimal conversion to 2, which will force at least two characters per value.
Remove the Decimate Array function.  You can connect the array of strings directly to "Concatenate Strings."
Message 14 of 15
(3,186 Views)
Thank you, it is working perfectly :).
Message 15 of 15
(3,180 Views)
