LabVIEW Menus
I have some vi's that I'm running in menu format, so as to be able to switch
between them. I know that changing the location of the vi on your screen
before running will change where it pops up when run, but this is tedious,
imprecise and can't get the menu into the location that I need. Is there
any way to tell the menu to appear in a certain location? I couldn't find
it in the menu options.
(3,239 Views)
I don't exactly know what you mean by menu format, but to precisely position
windows, you can use the VI Server to set properties of a VI, like position
and size.
Greg McKaskle
(3,239 Views)
