LabVIEW MilliSecs support manager function and Tick Count block diagram object
Is the output of the support manager function MilliSecs (used in a CIN) directly comparable with the time returned by the Tick Count (ms) block diagram object? i.e. if they have the same value then it is the 'same' time allowing for OS specific time resolution
(2,766 Views)
The LV diagram node is built upon the MilliSecs() function, which is
built upon various OS specific functions. It is safe to treat them as
though they are the same function and represent the same clock.
Greg McKaskle
(2,766 Views)
