LabVIEW-MultiSim Co-Simulation
Exe file of LabVIEW-Multisim Co-Simulation is not running on the machine, where I want to run it.
However it is running on the same machine, on which, it is developed.
How can I run it on the other machine?
LabVIEW and Multisim are having version of 2012.
(3,615 Views)
Hi Simutrical,
could you please explain your question? If I understand right, you want to run your VI co-sumulated with Multisim in another machine that there is no LabVIEW installed, am I right? In this case, you have to build .exe in labview project and check that in the machine is LabVIEW run-time engine (same version LabVIEW) installled. This tool is free and you can download from ni.com.
Regards!!
Patricio Cortes | NI Cono Sur
(3,378 Views)
I have downloaded your file and built the exe application from the VI, and I've found that it is not running. It is running inside Labview but not as standalone exe application. I am too interested to know why an exe application for the VI having Labview-Multisim Cosimulation fails to run. I have Labview 2014  & Multisim 14 installed on my PC.
(3,014 Views)
