LabVIEW NXG 1.0 installation error. installing package "VISA Shared Components"
Hi
I'm trying to install "LabVIEW NXG " On a laptop with windows 8.1,with no success.
It gets so far, then error 1603 appears.
Attached is an image of the error.
Thanks in advanced
(3,963 Views)
You need to install NI VISA found here: http://www.ni.com/download/ni-visa-17.0/6646/en/
You can then use package manager to install NXG.
(3,912 Views)
Accepted by topic author dearg
Thanks. Problem now fixed.
(3,907 Views)
HI, I´M HAVING THE SAME PROBLEM AND I´M USING THE SAME PACKAGE FROM THE LINK http://www.ni.com/download/ni-visa-17.0/6646/en/
(3,364 Views)
Hi acuña,
Are you seeing the same issue with a later VISA package? Could you try the VISA 18.0 package instead?
Frank
(3,337 Views)
