LabVIEW NXG Label Placement Top center
It seems like there is a bug with the changing of a control's label during run time that will cause the label placement to become offset from center. For example if I have a control with Top center as the setting for Label Placement like the following:
then if I change the label text via property node like this:
the label no longer centered about the control and offsets to the right from center like this:
I assume this is a bug that will need to be fixed but I was hoping as a work around I would change the position of the Label like this:
However, it doesn't allow me to change the Label position though, it errors out with the follow error. Does anyone have any ideas how to change the label position without getting an error? Or if the bug with with the centering will be resolved?
(2,611 Views)
Hello stillwaiting255,
Thanks for reporting this behavior. I was also expecting the label to accommodate to its position after the text changed.
I have submitted CAR #743906 for the appropriate team to review and follow-up.
(2,482 Views)
