LabVIEW NXG "getting started" interactive lessons do not work
Hello everyone,
I just installed LabVIEW NXG 4.0.
I am new to LabVIEW, so I wanted to do the getting started interactive lessons on the front page, but none of them seem to work. I do not know how the lessons should work either. Not depending which lesson i choose, LabVIEW opens the belonging project. I can see the prepared documents and VIs and have a vague clue on what to do, but there are no comments or similar.
What am I supposed to do or cklick on? Or is it just an intallation error?
Thanks in advance!
(2,509 Views)
Accepted by topic author Eggpiet
Thanks to NI support I was able to figure out the problem:
My laptop setup contains an external monitor. I usually work with the laptop display acting as a second screen. If LabVIEW NXG ist started while the windows 10 display setting is set to "expand" the monitor LabVIEW is not able to open any workbooks.
Opening LabVIEW with only one display enabled resolves the issue.
(2,425 Views)
