LabVIEW Newbie Questions
Hello all,
I have recently started working with LabVIEW. It would of great help
if somebody can answer my questions:
1. I have a pair of values, which I generate for every iteration of a
for loop.
How do I represent these points, with one value on X-axis and the
other on Y-axis (like XY Graph), as they are generated. I guess XY
Graph, does not plot on the fly. Is there any way to do this?
2. Are there any resources/books on good LabVIEW GUI Design.
3. I feel like the VI's get cluttered, as its complexity increases. Is
there anything that can be done to avoid this? I see that, SubVI's
can be a good solution, but is there anything else that can done to
avoid the the spaghetti.
4. Any comments on:
LabVIEW Advanced Programming Techniques by Ri
ck Bitter
LabVIEW GUI: Essential Techniques by David J. Ritter, Gary W. Johnson
TIA
Sreedhar
(3,514 Views)
3) Design your app before you start coding. Group related data values into clusters. Perform self-contained autonomuos functions in sub-VI's.
DO NOT use clusters just to reduce wire count.
DO NOT just grab a bunch of nodes and create sub-VI's.
Search for info on LV2 style globals and action engines.
Also look for info on state machines.
Ben
(3,514 Views)
1) There is no XY chart in LabVIEW, but we do have an example program that uses an XY graph to simulate an XY chart. It basically maintains a buffer of the previous entries and plots them with the new data
Go here Search/Upload Example Code and Type "+xy +chart"
2) I haven't read any books on GUI design, but you should check out this reference on our website: LabVIEW Style Guildelines
(3,514 Views)
2) I think David Ritter's LabVIEW GUI - Essential Techniques is what you are looking for.
www.vartortech.com
(3,514 Views)
