LabVIEW Object-Oriented Programming: R&D Technical White Paper (LV8.2)
The Decisions Behind the Design
A white paper from LabVIEW R&D
LabVIEW: A piece of software celebrating its 20th birthday this year. Is it a design tool? Is it a programming language? It is both, and because it is both it has been a major boon to scientists and engineers who need to program the computer without getting the computer scientists involved. Whenever we, the LabVIEW developers, want to add new features, we must consider that the majority of our customers are not programmers. In version 8.2, we are introducing LabVIEW Object-Oriented Programming (LabVOOP). Object orientation (OO) is a programming style full of abstract concepts and technical vocabulary. Most explanations of it require either an intimate knowledge of programming or a long learning curve. We aimed to streamline that complexity with the goal of making the power of OO accessible to a wide range of our users. The result may surprise OO proponents familiar with other programming languages. This paper lays out the design decisions and the reasoning behind those decisions as we created LabVOOP.
This paper assumes some familiarity with LabVOOP. You might consider reviewing the relevant sections of the LabVIEW Help and the example programs before continuing.
Message 1 of 16
(10,856 Views)
Woh...
20 Stars Smiley Happy
PS: Not all like MS.Docs .... maybe PDF?
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 16
(10,834 Views)
One pdf coming up Smiley Happy
2006 Ultimate LabVIEW G-eek.
Message 3 of 16
(10,810 Views)
Hello Aristos,
Good paper, very explanatory and documenting. I think this should be shipped with LabVIEW!!
It explains fairly deep which choices were made and the implecations.
I have one question: why is chosen for the name LabVOOP, it looks like NI wants to forget it has a programming language (G)?
Ton
My LabVIEW Ideas
Message 4 of 16
(10,800 Views)
Oopview sounds better..
Wiebe.
"TonP" <x@no.email> wrote in message news:1155060608161-401730@exchange.ni.com...
Hello Aristos, Good paper, very explanatory and documenting. I think this should be shipped with LabVIEW!!It explains fairly deep which choices were made and the implecations.I have one question: why is chosen for the name LabVOOP, it looks like NI wants to forget it has a programming language (G)?Thanks,Ton
Message 5 of 16
(10,693 Views)
The name of the feature is "LabVIEW Object-Oriented Programming." That's an attempt to *not* make it a separate language. But do you have a better acronym? At least LabVOOP is pronouncable. Besides.... it inherits from LabVIEW, and the "IEW" is encapsulated. 😉
Message 6 of 16
(10,625 Views)
Not flaming,
but it sounds like a marketing name, what is wrong with the good old GOOP (G Object Oriented Programming). Because (IMHO/knowledge) LabVIEW is a program to interface with G. Or is G on senior relief as a twenty year old?Smiley Very Happy
Ton
My LabVIEW Ideas
Message 7 of 16
(10,616 Views)
Jonnie 5 - Thanks for the PDF!!!
Out of curiosity, what's the syntax for defining a dynamically-dispatched VI?
G, I've been LOOPing for years! Smiley Wink
Of course some people have trouble applying the concepts; their programs are kinda' LOOPy (LOOP-like.) Smiley Tongue
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
Message 8 of 16
(10,550 Views)
For one thing, GOOP is trademarked by another company. NI can't use it. Further, the GOOP Toolkit continues to exist (and, indeed, Endevo will continue releasing new versions even after LabVOOP release). LabVOOP and GOOP Toolkit are not competitors directly -- they work well with each other and are used for different cases in LabVIEW programming. So using the same name would be a disadvantage to both.
Message 9 of 16
(10,499 Views)
Since it is not a new language, it doesn't need a new name.
Perhaps in the same line as c? LabVIEW++?
Wiebe.
"Aristos Queue" <x@no.email> wrote in message news:1155233412458-402771@exchange.ni.com...
&nbsp;
Message 10 of 16
(10,489 Views)
