LabVIEW PDA & NIDAQmx base 1.01 & CF-6004 doesn't compile
Hi all,
I just got my CF-6004, installed NIDAQmx base 1.01 for PocketPC2003 and tried to run a simple 1-channel AI task: LabVIEW PDA doesn't compile the code due to "missing VIs". The compile report says "unresolved external symbol".
The strange thing: The VIs that are reported missing are there in ...\Labview 7.1\vi.lib\_daqmxbase!
Included Example VIs don't work, either.
Anybody got an idea?
Stefan
Config:
LabVIEW 7.1.1, LV PDA 7.1, LV RT 7.1.1
DaqMX base 1.01
CF-6004
Attached you find the compiler report file.
(2,711 Views)
Again hi all,
the issue is solved - decimal separator must be changed from "," to "." on German Computers, that's it...
Stefan
(2,707 Views)
