LabVIEW PPL Version not visible in Windows Explorer
Hi all
I'm new to PPL's and i tried to deploy a PPL to a prodcution machine with windows 10 and only LabVIEW Runtime installed.
Know i wan't to verify that i have the correct PPL-Version on the Production machine but the Version-Property is not visible:
On the development machine with Full LabVIEW installed the version-property is visible.
Is it because *.lvlibp is a unknown filetype?
How to solve this behaviour?
Best regards
(2,422 Views)
Hello to all
Is my question not clear or is there no solution?
Best regards
(2,349 Views)
There is a hidden gem that you can use to get the version information from your PPL: <LabVIEW>\vi.lib\Platform\fileVersionInfo.llb\FileVersionInfo.vi
I have not tried it on a deployment machine yet, but you could make a very simple utility to get all of the PPL and executable files to check their version.
(2,343 Views)
Thanks Knight Of NI for your reply
That is a solution but that couldn't be that i have to write a extra utility to get the *.lvlipb Version.
Is there a other Solution?
Best regards
(2,307 Views)
