LabVIEW, Program Licensing and Domain
Im doing a research that requires me to build a system. To publish a paper for this standalone program (.exe), i need to have program licensing and upload it in a domain.
Does LabVIEW has a special domain and program licensing for my case? if they don't, could you suggest to me any domain that is suitable (preferably free).
Thanks.
(4,293 Views)
HI Nusnus
LabVIEW EXEs are free to distribute as you wish. The only requirement to run on a machine that doesn't have the LabVIEW environment is download and install of the the NI RunTime engine which you could say is a free downloadable license in a way.
Note: Some add on items like Vision and teststand require paid for runtime/ deployment licenses
The only other thing I can think is if you place a MIT License which is free and things like Ruby and Rust use
Hope this is helpful?
Cheers
Jono
(4,211 Views)
@JCH_26 wrote:
HI Nusnus
Cheers
Jono
Additionally, I think you have to include some LabVIEW-related copyright stuff in a readme or as an "about.vi".  I can't remember where in the LabVIEW folder I've seen this, though.
Bill
CLD
(Mid-Level minion.)
(4,197 Views)
True, i would have thought the MIT license in a readme would suffice? it's never really something we've done as In our case, the IP is either owned by us or the customer dependent on the project. Our about Run time menu items usually detail company info and release version number etc..
(4,192 Views)
Regarding the domain, you could upload your files to Github. You would need an account, create a repository, then upload your files to the repository. This would allow you to point some to https://github/username/respository to download your VIs/Libs/Projects.
(4,181 Views)
