LabVIEW Project not loading- stuck on RGT VIs
Hello all,
recently I've been fighting with a problem: I can't open one of my projects as it gets stuck on one of the report generation toolkit VIs upon loading. This happened both before and after a complete reinstall of LabVIEW. I've also tried doing a mass compile, but it gets stuck on those same VIs.
Eventually, the project will open, if I try enough times, which I only tried as I noticed that it getting stuck on different VIs each time, but obviously that's a nuisance.
It usually gets stuck on:
_office\exclsub.llb\...
_office\wordsub.llb\...
Where do I even start debugging this?
Remember Cunningham's Law
(3,481 Views)
It is likely to be one of four things:
  • Something is seriously wrong with your OS (which I assume is some flavor of Windows).
  • Something is amiss with your version(s) of LabVIEW (of which we have no inkling).
  • Something is sufficiently "buggy" in your code to hang LabVIEW when opening the Project (but it is difficult to pass judgment as we haven't seen the Project).
  • You found an obscure bug in LabVIEW (indeed, possible, but rare ...).
Lacking further data, I'd wager there's something strange about your code.  If I had a copy of your Project and knew which version of LabVIEW it required, I'd try loading it, try to understand what I saw happening, and if I "got stuck", would try to open selected VIs without opening the Project and study the behavior for clues.
Bob Schor
(3,444 Views)
I can only offer a lame reply.
Could Office have been updated?
Does a mass compile help out?
Ben
(3,440 Views)
