LabVIEW RAD Utility Image Can't Burn to DVD
Hello everyone,
I'm having a very strange issue with my .lvappimg files. They won't burn to a DVD unless I zip them into an archive! Any time I try to copy them to the DVD Windows tells me that the disk is write protected. I have a feeling that this is due to my corporate IT antivirus software (a custom McAfee build) restricting certain files being written but I have no way to confirm that. This same problem occurs with certain files in my LabVIEW installer builds. Has anyone else ever seen this issue?
(3,096 Views)
It does sound very strange, and not something I've run into before. You might try using ImgBurn (use the ImgBurn mirror to download) and burn the DVD using that, or use it to create an ISO and burn that with some other software.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(3,067 Views)
