LabVIEW RT runs slower and slower
I runs the same DLL program on LabVIEW RT several times.
But the CPU load becomes greater in subsequent runs.
Can anyone give me some idea about it?
Thanks.
(2,941 Views)
Accepted by topic author alexwu1017
Hi Alex,
what is a "DLL program"? Which "LabVIEW RT" (aka target) do you use?
What exactly is your program doing? Do you have any open references/resources not being properly closed?
But the CPU load becomes greater in subsequent runs. Can anyone give me some idea about it?
Most often it's a bug in your software…
(2,938 Views)
Thanks.
Not without seeing some (or better, all) of the code (VI's or zipped Projects only, please, no pictures).  You appear to be leaving some garbage behind when you stop the program, but without seeing the code, we can't begin to "guess" what that might be.
Bob Schor
(2,882 Views)
Thank you very much.
There found some memory leaks in code.
I think this issue comes from it.
(2,868 Views)
