LabVIEW RTE 8.2
Yesterday I installed LabVIEW RTE 8.2 in a PC to make some tests of the new functionalities. Now I want to uninstall it from the computer, which already has LV RTE 7.1, and I can not find it in "Control Panel">>"Add/Remove Programs">> "National Instruments Software", could anybody tell me how can I clean my PC from 8.2
Iñaki
(3,025 Views)
Couple questions for you:
  1. Does it show up as LabVIEW Run-Time under Add/Remove Programs, like Elsa's screenshot?
  2. Did you install any other National Instruments Software that might use RTE 8.2?  If you've installed any other NI software with it, it will be hidden in National Instrument Software - and will uninstall with the program that it was installed with.
  3. It wouldn't hurt to have RTE 8.2 on there - did it break any of your programs?
We could uninstall it manually (or atleast remove references to it), but let's make sure there are no dependencies before we go that route.
TheDillo
(3,006 Views)
