LabVIEW Real-Time Module Installer Error
While installing the latest LabView release I encountered the following error during the RT module install.  I made sure to follow the specified installation order , and did not install device drivers.
.\ConfigInfo.cpp(2723): IInstallerError 11006
Developer Error. The following errors were found in your ini file:
1. Missing Key: [MsiEngine] winNTpath
2. Specified file not found: [MsiEngine] winNTpath
3. Missing Key: [MsiEngine] CommandLine
Correct the ini file and try again.
<No Debug Mesage>
Thanks in advance for you help!
Best, Tom
(3,343 Views)
Hi Tom,
Try to copy the contents to your hard drive and then installing. Have you tried this on any other computer?
Warm regards,
Karunya R
(3,321 Views)
Hi Karunya - thanks for your post - it helped resolve my problem.
For others that are experiencing the same issue.....
I am running on a Dell Laptop w the detached DVD drive. I tried copying the DVD to my harddrive but kept on getting errors. I then took the whole thing home, copied the DVD through my home PC to a share, then installed the drivers from the share. The only issue I ran into is that at some point it is going to ask you to insert the second driver CD (eeeerh?). Point it a the directory ending in "-2", You would have probably figured out on your own, but hey! Good to know.
I connected the cRIO to my home network (on 192.168.x). MAX found it at 0.0.0.0. I enabled dyncamic IPs, and am now connected.
Life is good!
(3,201 Views)
