LabVIEW Real-Time module for RTX
I am developping an application that demands both deterministic behaviour and response to a user interface. It involves single point digital and analog input and output. So far I have used a PCI-6259 board and LabVIEW 7.1, but using a timed loop I can't go higher than 5 kHz which is not sufficient, even after changing the execution priorities.
I'd like to know if the Desktop PC-Windows extension Real-Time Target (Labview RT for RTX) would support my PCI board and DAQmx , or if it works only with reconfigurable I/O boards.
Is it fully compatible with programs written with Labview 7.1, too?
Thanks for answering
(3,369 Views)
I'm not sure that Real Time RTX is the best solution for you. The Real Time OS would just be running under Windows. That option is more for adding determinism to your system then increasing the speed and from your post it sounds like you want to increase the speed of your app.
Real Time ETS with a faster processor would be better as then you'd be using a PC dedicated to the real time OS, without any Windows interference.
There is only support for RTX under DAQmx Base (a stripped down version of the DAQmx driver) which doesn't support M Series devices. DAQmx has support for RT ETS however so you could use your PCI card in that system no problem.
Finally, whether your LabVIEW 7.1 code is compatible with Realtime will depend on how your code is written. If it is architected efficiently in windows then it probably will work, but labview for windows is a completely different environment to labview for RT. They do have alot of the same components so like I said, it probably will work but I couldn't say they would be fully compatible.
Hope this helps,
Sarah
Applications Engineer | National Instruments | UK & Ireland
(3,366 Views)
