LabVIEW Remote Panels with a cRIO
Hey all,
I have a NI cRIO-9082 that is running a RT Application that I created and deployed using a win10 PC. Now, I wish to view and control the front panel of the VI that is running on the cRIO. I followed the steps for creating a webserver using this NI link. However, when I connect to the cRIO using Internet Explorer, I can only see the html bits (header, title and footer). The remote panel section shows an error, "Server does not support Remote Panels". I have followed everything listed in https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9zJSAS&l=en-US  to try to fix the issue, but that hasn't seemed to work. I'm sure I'm missing something trivial. I have also come across some forum posts where people have mentioned that Remote Front Panels aren't recommended for RT systems. Any workarounds or help would be appreciated!
(2,466 Views)
Setting up Remote Panels for VI's on RT systems is a process of many steps. Attached is a link to the best *so far* on how to set them up.
Essentially these steps are:
1. In Max: Assure you have installed the Web Server package as part of the RT Software deployment. Don't confuse the WebDav with the VI Panel Server.
2. In the LabVIEW Project: Right-click on the RT system on the project Tree - Enable the Web server - then right-click -> Deploy the Front Panel Web Server Enabled configuration.
3. Create your RT Main VI
4. In the LabVIEW Project: follow the examples in the link to access Tools>Web Publishing Tool and create the html file template for your main VI. SIMPLIFY the name of your hmtl with NO SPACES - as you'll get the %20 html gobbledeegook [the default html name offered by the web tool interface is insanely long and complex...keep it simple - you'll need to type the exact http:\\ path and you can make many hairpulling mis-typing mistakes...]
5. In the LabVIEW Project -> RT Build Specifications: You need to follow the example link to essentially, push the .html file with your deploy Vi to a www directory on the RT.
*** the destination path for the www on the RT should be /var/local/natinst/labview/www
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHxcCAG&l=en-US
What can be a pain is figuring out the exact web address - for example here is an actual web panel access path: notice I used underscore _ in lieu of spaces - I also *think* it might be case sensitive.
http://10.0.10.5:8000/Mosaic_Ctrl_Main.html
I have to say this is very hit and miss - half the time I can deploy a Web panel with no issues - then on some systems - I can't...get the 'Server service is not running' or the VI does not exist...This leads me to believe there is an order to configuring that has a fragility - so if you don't do that - it breaks the function.
Regards
Jack Hamilton
(2,219 Views)
