LabVIEW Report Generation Toolkit in the application does not work
I have LabVIEW7.1 and LabVIEW Report Generation Toolkit for Microsoft Office 1.0.1, which was updated after installed. I made a VI in LabVIEW7.1 enviroment using the Report Generation Toolkit and it works very well. After the VI was build an application.exe and installed even in the same PC, the Report Generation Toolkit didn't work. Excel that should pops-up does not do anything.
the office i used is office xp. would you like to help me?
thank you very much.
Jing
(3,069 Views)
When you build the application, you have to include as "Dynamic vi" in Source file tab the vi:
_Word Dynamic VIs.vi. from _wordsub.llb
_Excel Dynamic vis.vi from -Excelsub.llb
in the following library
...\National Instruments\LabVIEW 7.1\vi.lib\addons\_office\"
Refer to the following discussion thread
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=50650000000800000053460000&ECategory=LabVIEW.LabVIEW+General
(3,069 Views)
thank you very much
(3,069 Views)
