LabVIEW Reports - Add "portion marking"
I haven't used the Report Generation tools much. How might I go about adding "portion marks" to a LabVIEW report?
I envision setting the report's current classification level as data is added, just like I set the font and point size. When the report engine is executed, the appropriate portion marks would appear in front of the data, and the appropriate classification level would appear in the header and footer of the page.
An overview of creating classified documents is available here: http://www.archives.gov/isoo/training/marking-booklet.pdf
MS Office probably won't be available on my test computer, templates are not an option.
(2,725 Views)
Phillip-
You should jsut be able to use the Set Report Font.vi to change the font and color of the text for the portion marks. You will, however, need to have Office on the computer running the VI as the report generation toolkit uses activeX calls to Office to generate the reports.
Xaq
(2,702 Views)
