LabVIEW Resource not found - Several
We have several executable files which work fine in our old WIN XP machine. Some require LabVIEW run time engine 2010 and one requires 8.6.1. Due to our ICT requirements, we are looking to migrate our executable over to a WIN 10 machine.
We have installed LVRTE2010_f2Patch. The apps that required this run time engine have worked fine on WIN 10.
The problem we are having is with the LVRTE861min. The app that requires this is not working properly. I have screenshotted all the msgs that have come up when the app first tries to run.
I have tried searching online, but haven't come across a fix for this issue. If anyone in the community could help, this would be greatly appreciated.
(1,964 Views)
Hi NZDAZ,
What about converting the source code of your LV8.6 program to LV2010 and recomppile again?
What about upgrading to a recent version of LabVIEW with official support for Win10 and recompile all again?
(1,900 Views)
If the goal is just a LabVIEW version compatible with Windows 10, then you need at least LabVIEW 2015 SP1.  But, yes, if you are upgrading, might as well go full modern, currently 2020 SP1.
(1,887 Views)
