LabVIEW Retrieve Attachments File
Hi All
I am looking for the example code to retrieve attachments file from Outlook using ActiveX!
Please give me some advise!
Luong.Tran
(6,013 Views)
(6,009 Views)
Can you save the vi for 2012 version and post it please?
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(6,000 Views)
Accepted by topic author Luong.Tran
Hi Sir
Please see the attachment file
(5,975 Views)
Hi Luong.Tran,
Can you please provide more information? For example: What is the error code you see when you run the program? I notice that when I run your code, I see error code: -2147352567. Is this the error code you are seeing.
Below is a link with steps for how to fix this error code issue:
Why Do I Get Error -2147352567 When Opening a VI Using Active-X in LabVIEW
http://digital.ni.com/public.nsf/allkb/7BB7805980B62383862572BA00568D5E
After following the steps in this KB, and if you are still experiencing issues, please let me know. Thanks!
Kevin S
(5,895 Views)
