LabVIEW Robotics 2010
Hi Friends,
                I'm Mari. I like to do my final year project in the field of ROBOTICS so i prefered LabVIEW platform for it and i m new to LabVIEW Robotics. So i have doubt whether is it possible for me only to simulate my project in just software with the mdules available and without making use of the NI Robotics Hardware since i m not wealthy enough to buy the hardware. So kindly help me in this regards.
Thank you.
(4,134 Views)
LabVIEW Robotics 2011 introduced an Environment Simulator that should help you simulate a meaningful project. I would highly recommend you upgrade to that version as it provides significantly more simulation capability. There have been some classes that taught in simulation and then had final projects with real hardware. Whether or not a project solely based on simulation would be sufficient for your final project depends on your instructor and the guidelines for the project.
(2,498 Views)
