LabVIEW Run-Time Engine 6.0 Error 1606
I try to install LabVIEW Run-Time Engine 6.0 on a PC running Windows Me. As soon as the installer wizard apear, the message follows "can't find network location ..\. Error 1606
(3,052 Views)
There is an article in the NI KnowledgeBase describing this problem. I recommend you visit www.ni.com/support and search the KnowledgeBase for "1606".
The KnowledgeBase is the best place to start when you have technical support questions like this. Good luck and have a nice day.
Darren
(3,052 Views)
