LabVIEW Run-time 2009 SP1
When I try to install LabVIEW Run-time Engine 2009 SP1 on a Windows 2000 machine I get an error message that states "Windows XP SP2 or greater required"
The compatability chart https://www.ni.com/en/support/documentation/compatibility/17/labview-and-microsoft-windows-compatibi... states that LV 2009 is supported on Windows 2000. What gives?
(4,068 Views)
What windows installer are you using to install the run time engine?
(4,036 Views)
I tried the installer in the 2009 project, selecting "Windows 2000 or later".  I also tried the 2009 run-time (std) download from NI.
(4,027 Views)
Do you have administrator privileges?  Also, do you have any security programs installed on your computer that could hinder the installation?
(4,010 Views)
