LabVIEW SQL Toolkit and Oracle 8i - need alternatives
We recently upgraded our databases from Oracle 7 to 8i (8.1.6).
Immediately found out that LabVIEW SQL Toolkit is not compatible with
the shipping version of Oracle. If you have a VCHAR field over 255 the
toolkit reads garbage. NI admits to this and is working on an ADO
upgrade version due out ? that will fix all of these problems. In the
mean time I am wondering if anybody controls SQL through some other
application under the control of LabVIEW? Got any ideas or knowledge of
an alternate SQL method let me know.
Jim Morrison
(3,923 Views)
You could write a DLL using Visual Studio to perform the SQL actions needed
and then import the DLL into LabVIEW as a shared library, if you were
desperate.
Dave Gianetto
http://www.gianetto.org/
> From: James Morrison/Joan Lester
> Organization: Airnews.net! at Internet America
> Newsgroups: comp.lang.labview
> Date: Tue, 05 Dec 2000 23:07:33 -0600
> Subject: LabVIEW SQL Toolkit and Oracle 8i - need alternatives
> Hello,
> Regards,
> Jim Morrison
(3,923 Views)
James Morrison/Joan Lester writes:
> Hello,
> Regards,
> Jim Morrison
Jim,
My knowledge about SQL and Oracle is quite limited, but it should use
a TCP/IP connection between Client and Server like (nearly) a
ll
services do. You just open a TCP connection to the right port, do the
login procedure, fire off your SQL commands, wait for replies and
close the connection.
Commands are expected to be plain text, so the SQL Toolkit should not
have any "black magic" in it. It's just a question of time and money
to roll your own SQL Toolkit.
Johannes Niess
(3,923 Views)
Thanks for the reply. I may just try doing this. Typically though the SQL
toolkit uses ODBC on your machine to talk to an Oracle client on your local
machine. That machine in turn talks to the database specified via a socket.
What the client does I don't know? Its a good point though, I have the IP,
I'll just fire an SQL off and see what happens.
What really is making me mad is that TestStand and CVI has no problem with
Oracle 8i, only the LabVIEW SQL Toolkit. So you wonder why NI just doesn't
creat the LabVIEW SQL toolkit out of a CVI dll? Baffling.
Jim
> > Hello,
> > Immediately fo
> > Regards,
> > Jim Morrison
> Jim,
> a TCP/IP connection between Client and Server like (nearly) all
Johannes Niess
(3,923 Views)
If you are experienced with ActiveX and labview,
try using the old DAO (Data ActiveX Objects)
activeX objects to access the database. I'm sure
that you will be able to read the data write.
regards,
Abdullah
In article
<2C5DAFEE74818E6D.8F015D896DD0E490.A80401DED3796EA
A@lp.airnews.net>,
wrote:
> Hello,
7 to 8i (8.1.6).
SQL throug
h some other
> Regards,
> Jim Morrison
Sent via Deja.com
http://www.deja.com/
(3,923 Views)
