LabVIEW Task Bar Behavior - Icons stay on the 'main' monitor instead of moving with the window
As part of a computer upgrade, I've run across a behavior I don't remember previously that appears to have been around for a while. It appears have been previously reported on CAR 550071. My google-fu has not turned up any additional information on that number.
I'm running Windows 10 Pro, build 19041.450, with the task bar set to never combine Icons and show task bar buttons on the task bar where the window is open. I'm using 3 monitors (2 external + 1 built-in). I see the issue on LabVIEW 2019 both 32 & 64 bit (19.0.1f3), as well as LabVIEW 2016 64-bit (16.0f5), and LabVIEW 2015 32-bit (15.0.1). Which is to say everything I have installed that lists Windows 10 as a supported OS on the Download Page.
Hopefully, I'm just missing a setting somewhere. Does anyone else know how to get the task-bar icons to show up on the same monitor as the vi window or am I the only one having this issue now a days?
Thanks!
Message 1 of 1
(1,093 Views)
