LabVIEW Touch Panel -- I can not get activesync to connect between the TPC-2012 and my XP workstation. There is no USB client connection on TPC-2012
Hi David,
thank you very much for your help. It seems that I really cannot do much without having Touch Panel Module. This fact makes me even more unhappy because when I was buing the whole system, I was pretty sure, that I can run the application without having additional costs(the system was choosen by an ni employee). Now as the whole budget for the project is closed I have not much opportunity to use my TPC:)
So, I have last two questions... Would it be possible to develop the control application for PXI RT in LabView and separatelly to develope a visualisation(for example in VB)  run it on TPC 2012 and then to communicate it with PXI RT withou having Touch Panel Module?
Do you know where can I check what modules should be included in LabView 8.2.1 and 8.5 versions?
Thanks.
Martin
Message 21 of 22
(791 Views)
Do you have LabVIEW Realtime? You might be able to access the same shared variables, I will have to do some research to see if that is possible with out VB API.
What have you tried so far?
Anna K.
Message 22 of 22
(760 Views)
