LabVIEW Unspecified Error
I've been getting this error while running a TestStand Sequence with LabView modules, any clue???
(3,933 Views)
Hi, N.
I'm not sure what the rest of your code looks like, but I just did a quick search and came up with these two possibilities:
Passing an Automation Refnum From a VI to a Call Library Node
TestStand Run-Time Error -10 When Opening Database Repeatedly
Though that second link mentions error 10, it talks about error 2147467259 inside the KnowledgeBase, so it still might be worth a look.
If neither of those is fruitful, can you tell us a little bit more about what you're doing in your code? You say you have multiple modules -- does this error pop up on any of them, or only a certain one? Does it happen 100% of the time? If so, I recommend watching the code with Highlight Execution (the lightbulb icon) on. If we can determine what in the code is causing the error, we're halfway to the solution.
Have a nice weekend!
Sarah K.
Search PME
(3,910 Views)
i got also  this unspecified error.
This problem occurs when creating data in EXCEL format and also automate to create graph using MS Excel 2010. i got no error when creating the same data in MS Excel 2000.
i am using labview 7.0 and 7.0. or Is this version of labview supports MS excel 2007/2010?
Thank you,
You could email.
Randy
randy.dechavez@rldp.com.ph
(3,582 Views)
i am using labview 7.0 and 7.1. or Is this version of labview supports MS excel 2007/2010?
Thank you,
You could email.
Randy
(3,580 Views)
Hi Randy,
LabVIEW 7.1 was released in 2004 so it does not have support for Excel 2010. You are going to haveto stay with Office 2000/XP or upgrade LabVIEW 2010 to support Office 2010
Joe Daily
may the G be with you ....
(3,571 Views)
thank you for the reply.
(3,561 Views)
