LabVIEW V6.0.1 tab control body invisible when run with scale & full screen option
In LabVIEW 6.0.1 the body of a tab control disappears (only tabs remain visible), when the VI is run with all options selected in Window sizes property.
(3,005 Views)
I had exaclty the same problem!!!
And the funny thing is that it is not systematic but accidental.
I believe this is a bug of LV 6.0.1 and I don't know if it was fixed in 6.0.2 (the documentation doesn't mention it).
(3,005 Views)
This issue isn't fixed in 6.0.2, but we are aware of the problem. The issue is with the Scale all objects ... functionality. You can see this by only checking that option and then rescaling the window.
Marcus Monroe
(3,005 Views)
This problem appears also without the Scale all object functionality, I'm quite sure of it.
(3,005 Views)
I have the same Pb in LV 8.5 is it still a bug?
(2,479 Views)
