LabVIEW VHDL
Does LabVIEW FPGA generate VHDL that is IEEE1076 compliant?
Thank you
(2,788 Views)
(2,757 Views)
Hello, Thank you but unfortunately this is a different tool for generating IPs and incorporating them into FPGA. I am talking about the NI91XX family devices and their LabVIEW/Xilinx ISE programming environment.
(2,641 Views)
VHDL is generated but it is encrypted.
Is there more context to your request that you can share?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,619 Views)
Yes the VHDL is encrypted but I hear it is possible to obtain a method to decrypt it with an NDA with NI. There is a requirement in one standard IEC62566 that the VHDL should be compliant with IEEE1076. The question is whether someone knows if once decrypted, the VHDL is compliant.
(2,596 Views)
https://www.ni.com/en-us/shop/product/labview-fpga-ip-export-utility.html
The above is a tool which you can buy or evaluate that does that.
ALE Consultants
(2,589 Views)
