LabVIEW VI Compiled Information Storage Path
Hi zVisior,
@zVisior81 wrote:
I'm sorry for opening this old thread, but have you found any solution o this problem?
Create lvlibp files from your VI libraries and have TestStand call the VIs from within the packed libraries!
So you can ensure you always provide compiled code to TestStand…
Message 11 of 12
(537 Views)
Hi GerdW,
Problem solved. Thank you for your suggestion. It works perfectly.
I also did check what happen if I only change folders to public documents but it still was returning an error.
Thank you.
zVisior
Message 12 of 12
(512 Views)
