LabVIEW VI scripting - save generated VI
Is it possible to automatically save a generated VI (using LabVIEW VI scripting) under a specific target that is already added to the project?
(6,893 Views)
Yes. The easiest way to do this is to open the VI in the proper context. Both Open VI Ref and New VI have an application input. Use this with an application reference from your specific target to open the VI in the proper context. Then save normally.
One way to get the application reference is the following sequence:
  1. Application property: Project.ActiveProject
  2. Project property: Targets
  3. TargetItem property: Name (filter to find correct target)
  4. TargetItem property: Application
There is probably a faster way, but this will work.
(6,859 Views)
It is still not clear to me how to do that from your answer. Could you add a photo of those steps?
(6,771 Views)
Accepted by topic author chikenene
I think DFGray is trying to do something like this.  There is also an Invoke Method for the Target Item class to add a file.
(6,751 Views)
I can't save my autogenerated VI...😓
Can I have some help please?
(3,755 Views)
I would suggest looking at the error you get, but I'm guessing that the error is that you probably need to give the full path to the VI and there's probably already a folder called Tarjetas on your desktop, so LV can't save a VI with that name.
Another potential issue is that you might need to create all of the folders in the hierarchy of the path (I didn't check) and there's an OpenG VI which does that (there's also a shipping VI, but that returns an error if the path already exists, so you have to filter for that error).
___________________
Try to take over the world!
(3,726 Views)
Sorry for the late response.
For some reason, it wasn't saving the VI if I generate it from a VIT.
I chose to save a pattern VI, copy and paste it, and then modify it before the saving. This way, it doesn't give me any errors.
JonA
(3,337 Views)
