LabVIEW Web Service Error(Write Response.vi)
Hello.
(I don't speak English. I wrote the following by Google Translate.)
I'm developing a program to communicate with webvi(NXG).
Use http method POST, transmit the state in webvi(or another way).
In LabVIEW Web Service, I would like to send a connection success message in response.
But, I got the -67304 error in "Write Response.vi"
As a result of testing through a probe, Except for "Write Response.vi", it run normally.
I want to get any ideas. Thank to your Attention.
My Development environment
LabVIEW 2019 Professional Development System
NXG 5.0 Professional Development System
OS : Windows 10 pro
CPU : intel i7-7th
(2,314 Views)
Hello Jively,
This issue seems to be related to the Web Service Properties
  1. In the LabVIEW Project right click on the Application Web Server and select Properties.
  2. In the HTTP Method VI Settings check the Web Service VI Properties»Output Type for one of your Web Service VIs.
  3. It is possible that Stream should be selected for the Output Type.
(2,234 Views)
