LabVIEW Web server with Reverse Proxy server
We have a LabVIEW exe running with web server enabled. When we configure a Reverse Proxy Server on a firewall computer to expose the html files on the LabVIEW computer everything works fine except the My_cool.vi
command.
I've tried My_cool.vi
without success.
Apparently the Reverse Proxy server will not allow the LV web server to generate the image and pass it along.
Is there a html solution?
Rich
(3,047 Views)
Rich,
Reverse proxys can be very "picky" about the type of information that they let through. In this case, the problem is probably the ".snap" expression. What we want to do instead is use the VI Server to produce a .jpg image that will reside on the server computer. Then, we can simply use the IMG SRC... commands to view the .jpg.
1. Place an invoke node on the block diagram
2. Change the VI Server Class to "VI" (right- click)
3. Select the method to be "Get Panel Image"
4. Place a "Write JPEG File.vi" on the block
diagram
5. Connect "image" to "flattened image
data", "colors" to "color table", and "bounds"
to "rect". Connect an "8" constant to depth (8-
bit). Wire a path control to the JP
EG path
(where the image is to be stored)
Now that we are making a .jpg file, we can view it in the LabVIEW .html file by adding the appropriate tag to the .html file.
Good luck,
-gaving
(3,047 Views)
