LabVIEW XY Graph slows down the application
if the XY graph is filled with a lot of data a tab change slows down the application.
Enclosed the VI with three curves with 100k data points each.
Are there any UI elements other than the XY graph or options that prevent a redraw?
Any Ideas?
The amount of data to be displayed should not be reduced.
B/R
Bastian
(1,629 Views)
Hi Stocki,
Any Ideas?
Use a different point style, like the small "+" or just a small ".". This already speeds up the graph a litte bit…
It doesn't make a lot of sense to display 3×100k points in a graph of just ~700×250 pixel size.
I really recommend to reduce the size of your plots…
When you place the graph on a tab container and switch between tabs then LabVIEW has to redraw the tab content when it becomes visible again…
Idea: don't place the graph in a tab container!
(1,618 Views)
+ Use singles in stead of doubles... Less data to copy, more speed.
+In stead of drawing the points, draw only the new points in the graph's embedded picture (Picture front, back or middle). This sounds like a lot of CPU power, but you can keep a 2D array in memory, and only add a point to it, then update the graph's picture. You do need to update all points when the scale (X or Y) changes. Or disable scaling (if possible). I've used this once for a project where the number of points where pretty much infinite.
(1,612 Views)
