LabVIEW & Multisim Cosimulation using Different Language
hi,
I am running LabVIEW 2017 & Multisim 14.1 Cosimulation.
If i changed the System language as Tamil (Other than English) and while calling the Multisim file inside the LabVIEW, i am getting the following error.
Error 1097 occurred at Call Library Function Node in SIMX EMI Model Initialize.vi->SIMX EMI Update EMI Node.vi->SIMX EMI Call Choose EMI.vi->SimX.xnodeSmiley FrustratedimX_OnDrop.vi:4250001->SimX.xnodeSmiley FrustratedimX_OnDrop.vi.ProxyCaller
Possible reason(s):
LabVIEW: An exception occurred within the external code called by a Call Library Function Node. The exception might have corrupted the LabVIEW memory. Save any work to a new location and restart LabVIEW.
Also while closing the labview, it crashes.
Expect, LabVIEW & Multisim Cosimulation, mostly all other functions are running smoothly.
Could you please someone suggest me the solution to run the cosimulation file other than english ?
Thanks & Regards,
Rajasekaran V
Thanks & Regards,
Ilamparithi Tamizhanangu
(3,867 Views)
hi everyone,
the  problem is solved by setting the system format as "English".
Control panel > Change date time or number formats > in the format tab ,select the  format  as "English".
Then change the display language as  "Tamil".
Now LabVIEW Co-simulation works good.
Thanks & Regards,
(3,739 Views)
