LabVIEW and C code
No, you don't.
What you have to do is to implement  the TCP/IP server on the Labview side and the client  on the C side.
And you have to choose a protocol for the tranferred data.
At the end you'll have two executables talking to each other.
As a side benefit the two executables could run on two different machines.
Marco
Message 11 of 15
(1,441 Views)
What part is it that you need to do from within LabVIEW?
If it is only the acquisition which is part of the NI-IMAQdx driver. You could just call those acquisition functions directly from C.
Best Regards
Anders Rohde
National Instruments Denmark
Message 12 of 15
(1,415 Views)
Oesen's license is for CVI 2.1 though, which looks ancient. Does that include NI-IMAQdx support?
Certified LabVIEW Developer
Message 13 of 15
(1,386 Views)
From his post it sounded more like he was interested in creating a component i LabVIEW and ship and to his friends computer. So I don't think that the CVI compiler is the one to be used, but we need more info here. So I doubt that it would make a difference.
But if he can create a LabVIEW DLL which includes call to the IMAQ dll then there should be no problem in calling the IMAQ dll seperately as well.
I'm a huge LabVIEW fan so I don't normally recommend people to avoid LabVIEW but in this case it sounds like a big overhead to create a LabVIEW module for calling the vision functions from C when you can already call the native vision functions directly.
Best Regards
Anders Rohde
Message 14 of 15
(1,369 Views)
Hi Anders.
I didn't know that i directly could call those acquisations from C. Due to my personal experience, it is long time ago I worked with C, so I prefer to do this solution in LabVIEW, otherwise my 2 weeks of working will be lost.
Best regards
Oesen
Message 15 of 15
(1,349 Views)
