04-06-2015 07:27 PM
I want to use LabView to read and write from a DLP RFID1 reader. But I am very new to this and need some starter help.
04-06-2015 08:15 PM
04-06-2015 08:34 PM
04-30-2015 01:59 PM
How do i know if I have the NI-VISA? I just got the student edition of LabVIEW to work with these.
04-30-2015
02:10 PM
- last edited on
08-22-2026
01:22 PM
by
Content Cleaner
Look in Measurement and Automation Explorer (MAX) to see what is installed. If you only installed LabVIEW, then you don't have VISA. Download it - https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html#306025
05-01-2015 09:43 AM
Still nothing after installing NIVISA. Not really sure where to go from here.
05-01-2015 10:01 AM
05-01-2015 10:48 AM
I am sorry my posts are short. I have installed the ftdi drivers. It shows up as an USB serial converter, location Port_#0003.Hub_#0002 in device manager. It is not visible in Max, that is what i meant. I do not get a com port for it in MAX. So then I built a small vi with Visa, but i cannot pick the reader.
05-01-2015 10:57 AM
05-01-2015 11:17 AM
Thank you for your help. I installed the combined drivers with the D2XX and VCP. http://www.dlpdesign.com/cdm20830certified.zip
I had the D2XX drivers enables for a demo program that i downloaded from http://dlpdesign.com/rfrdr/ . I did change that so the VCP drivers are loaded and now MAX recognizes my RFID as COM5. I also ran it through the vi quickly and added a screenshot of the output. If i come up with more questions after working with my professor, i will post on here. Dennis_Knutson thanks again for your help.
