LabVIEW and Microsoft Office Excel 365 Error -2146827284
Looks like here we go again in that I see someone had a similar post a while back:
LabVIEW code generates: Error -2146827284 occurred at an unidentified location using LabVIEW 2019 or 2020 with Microsoft Office Toolkit and Microsoft Office 365.
The issue is:
Code will generate error if Excel Sheet is set to minimized during execution.
Code will not generate error if Excel Sheet is set to minimized and Excel Merge Cells.vi is disabled.
Code will not generate error if Excel Sheet is set to maximized.
I found there is a CAR on this issue: 530624
So NI is aware of the issue.
Solution is to set file to maximized or normal mode or don't use the Excel Easy Text function.
Message 1 of 1
(2,248 Views)
