LabVIEW, append image to excel
Hello everyone,
I am trying to move an image into an excel spreadsheet, but I receive the error you can see in the attachments.
I also include the VI.
I would appreciate some help, as I do not understand what exactly goes wrong and how to fix it.
Thank you all in advance.
(7,245 Views)
Accepted by topic author akara
It looks like it can't find your image. What is your image path?
(7,223 Views)
GregoryJ is probably correct as to why you got the error.  When I ran your code with a path to a .PNG in the "Path or URL of Image" input, Excel opened with my image in Cell A1 and no error.
Bob Schor
(7,214 Views)
Thanks for your reply but I doubt that the issue is that the picture cannot be found.
I am almost certain that the issue comes from the fact that I have a 32bit excel and I am using the 64bit LabVIEW
(7,200 Views)
I am using LV 2017 64-bit and an excel 32-bit, but the VI works correctly! Excel opens with an image on A1 and no error.
I agreed to the post before and think that there is a problem with the path to your .png file
(7,197 Views)
Hi Guys,
Yes you are right.
I am using a constant for the figure path and not a control and my problem was that I forgot to add the extension of the image and apparently that caused the issues. I am testing it now and it looks ok.
Thanks a lot for you quick response guys and I am sorry for my stupid question.
(7,192 Views)
Don't forget to mark GregoryJ's quick response as the "Solution" (only you can do that).
Bob Schor
(7,170 Views)
