LabVIEW as an in-process COM-server
Hello:
At the moment, I evaluating if LabVIEW is the best tool suitable for my next task.
I would like to know if LabVIEW is an in-process COM server—an ActiveX DLL—that implements the IDTExtensibility2 interface. I am trying to add a COM add-in for a current Microsoft product.
The MS notes also states the following:
Non-modal forms cannot be displayed directly from a COM add-in. If you have non-modal forms, you can have your add-in call an external program (such as a Visual Basic executable) that enables a connection.
Does LabVIEW meet these criteria or do I have to program in VB?-((
Robert
(3,022 Views)
LabVIEW is not an in-process COM server. LabVIEW is started as a
separate process either as development system or as runtime executable
and the Active X interface is out of process to the other application
invoking LabVIEW's Active X interface.
LabVIEW is also not embeddable into other applications through Active X.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,022 Views)
