LabVIEW at 20!
I started using LabVIEW in 1996 (version 3.0 / windows 3.1) for a fuel pump/contamination test system using an SCXI 1001 DAQ system, but a couple of months later switched to version 4.0.  I have seen it getting improved over the  years.  LabVIEW was the only development software used at my work (the last ten years) for over 50 test systems built, in addition to supporting the local test lab. I would say "HAPPY BIRTHDAY" LabVIEW.
Message 21 of 176
(5,745 Views)
Hi:
Oh!, I can see very experienced people around here!. My first contact with LabVIEW was with LabVIEW 6.1 at somepoint of 2004. I saw a file with the extension "vi" in the desktop of a PC in my school and I couldn't resist to double-click it to see what the hell was that kind of file I've never seen before. After a few moments LabVIEW appeared in front of me for the first time ... but I said "Uhh I don't know what's this, I better close it".
After a month a professor introduced us to LabVIEW and still it wasn't more than "other" software. It was until I could put my dirty hands on an Evaluation Copy of LabVIEW 7 that I fall in love with LabVIEW, using that Evaluation Copy I knew LabVIEW was the ideal Programming Software for me!
Robst - CLD
Using LabVIEW since version 7.0
Message 22 of 176
(5,745 Views)
Next year we can take labview out for a drink when it is 21!  If labview is as good at holding its liquer as it is processing data we could be in some serious trouble (not applicable outside the US) .
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 23 of 176
(5,745 Views)
I started in 2000 with Labview  5,0999999999999996  Smiley Wink
Had been programming a lot in Turbo Pascal before.  Switching proved to be really simple. Tought it myself in a few days.   I still absolutely love Labview.
A few months later I was asked to teach Labview to our students .    Boy, that was an eye opener.  These guys managed to produce the most hideous code you've ever seen.  Things I had never even dreamed about.  I really couldn't believe what kind of mess they made.
The term "spaghetti code" got a whole new meaning with Labview! Smiley Very Happy
Message 24 of 176
(5,744 Views)
My first encounter with LabVIEW for a project occured in the fall of 1992. I was tasked with building a test system to test a complex module that had multiple analog inputs and provided its output in the form of a digital telemetry stream. I was supposed to build the test system using HPBasic ("we have more people that know it")  rather than the Turbo Pascal that the previous ones. NI did a demo at a hotel near where I worked showcasing "LabVIEW 2.5 for Windows and Unix". I came back and somehow convinced the project lead to let me try it! My first program ended up requiring me to write a driver for a HP control system analyzer (a combination of digital/analog input spectrum Analyzer, sort of). I mistakenly started writing a complete driver, rather than the parts I ultimately needed. Whew, a lot of coding in a completely new "paradigm" (really over-used word in the software world back then). Had other engineers look over my shoulder and comment about being paid to play video games. Used a lot of sequence structures, largest connector pane, etc. I will say in my, Ben's, etc.'s defense that the early examples used a lot of sequence structures. Left printing out of test results to last, how hard can it be, I had done it in Pascal, C and Fortran. Oop's, no way to easily just print out a page of text. When I called support the young lad asked "why do you want to?" I mentioned that my customer (U.S.Navy) wanted hard copies of the results, not just our assurance that it passed! His recommendation was that I build a VI with a text control that fit the entire FP and then just execute a screen print. Unfortunately this was before high speed inkjets or laser printers were common, and cheap, so it meant dumping Mbytes of image to an HP dot matrix printer, a very Loooong process. Quite educational, as was the next project which was supporting a large test system, running 2.2 on a Mac, which took almost 30 minutes to start the program! Literally click on the icon and go get coffee! Ran into that original project lead at an NI Tech symposium a couple of years ago, he had taken the plunge and was "dabbling" in LabVIEW. Commented to me, "Wow, now I understand why your were so psyched about using LabVIEW".
P.S.   Those who remember the early days won't forget to save early and often, lest you loose a bunch of work due to an "Insane Error"!
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 25 of 176
(5,727 Views)
My first encounter with LabView was around 2000 with 6.0. The company I worked for was implemnting a flexable testset scheme for all of the products we were manufacturing. I was programming test code for two different Digital boards that were part of Radio modules used in CDMA and UMTS Cellular Base Stations. The Labview code was run with Teststand on the Testsets. I also coded a Troubleshooting software for the boards which allowed the user to run single tests as well as manually send commands to the boards. I previously coded using C+, HP VEE, I also did some Database and macro coding using VB. All in all Labview is the best language I have used.
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
Message 26 of 176
(5,692 Views)
I was using LabWindows for my test software development until LabVIEW 2.0(?) ported over to the PC.
Randall Pursley
Message 27 of 176
(5,686 Views)
First used Rev 3.0 (1993) on Windows on a project to measure the unknown volume of a specimen in a production application, to replace a project I did in 1982 built with custom hardware. The original hardware crashed a lot Smiley Wink
The Rev 3.0 solution is still running today!!!!! this system does not crash Smiley Tongue
I think I first saw Labview on a Mac in the late 1980's, but the company refused to buy a Mac....  they were too expensive. We were using Z80's and similar stuff based on Z80 and similar hardware I designed; by the late 1980's were using a CPM style realtime OS in 32K bytes of ROM. It took months to get projects any where near a functional prototypes, lots of wires, static RAM, EPROMS and assembly listings.
LabVIEW memories
There was no undo function, if you didn't back up your files every serious change and needed to go back then you were in big trouble. The display screen was 640 by 480 dots with 2 colours, black and white or in fact green on black cos the monitor only had one phosphor color. The functions were on menus and always seemed to come over the critical part of the diagram....It was like looking at a map of New York and trying to find your way to the other side by looking only two streets ahead at any one time! Technical support was by facsimilie or telephone line to real people, and often I would ring from Europe to the states to get a specific answer, even the telephone lines had delays on them. Staying back late or coming in early to help with the time zone difference and telephone charges there was no 24 hour support forum then.
All my programs fitted on one floppy disk!!!! I had two floppy disks for Labview.
Message Edité par Conseils le 02-03-2006 11:27 PM
Message 28 of 176
(5,680 Views)
Nice try Smiley Very Happy
It looks like a phospor screen and it definitely is an early Windows version of LabVIEW, but the Windows XP window decorations make it VERY unlikely that this is running on a computer with phospor screen Smiley Very Happy
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 29 of 176
(5,665 Views)
Maybe Conseils' old computer was just way ahead of its time!
-D
Message 30 of 176
(5,661 Views)
