LabVIEW calling Visual Studio dll - error - "Debug Assertion Failed"
Dear Forums,
I have been making wrappers for c++ codes written Visual Studio 2008  for some time now. I have recently been working with a new c++ application.
However, this time, I am getting an expected error. Stranger, the code calling the dll has worked previously. With no edits, I closed LabVIEW for a few hours, opened it again - and this error message (see below) has appeared ever since. I have tried rebooting the computer, rewriting the subVI and checking the function prototype.
Does anyone know what this debug assertion failed message is trying to indicate?
This appears when I run the LabVIEW VI when it calls the Call Library Node. It does pass back and error boolean as designed in the c++ code.
Note: All other c++ wrappers and LabVIEW code works, just not this one.
Any advise would be very helpful indeed.
James
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(5,355 Views)
Hi All,
Regrettbly I am still having problems with this.
I am trying to write LabVIEW wrappers for ICE (by ZeroC) networking code written in c++.
I have a new error message as I retry to debug the application.
Any other suggestions?
Thanks, James
Kind Regards
James Hillman
(5,302 Views)
Accepted by topic author Hillman
Hi All,
I have now resolved the issue I was having.
The dll needed to be in the same location as a dependence config file.
Ta,
James
Kind Regards
James Hillman
(5,279 Views)
