LabVIEW caught fatal signal
I am running the LabVIEW HTTP-server on a Linux server. When the traffic is to high LabVIEW crashes and I get the following error:
6.0.2Received SIGSEGV
Reason: address not mapped to object
Attempt to reference address: 0x0
See LabVIEW_Failure_Log.txt for more information.
The LabVIEW_Failure_Log.txt looks like this:
#Date: Mon, Feb 18, 2002 02:48:30 PM
#Desc: LabVIEW caught fatal signal
#RCS: unspecified
#OSName: Linux
#OSVers: 2.4.16
#AppName: labview
#AppKind: FDS
0x40257840 - __libc_sigaction() + 0x1f0
0x083f2fbc - Exec() + 0x280
0x082a7fb5 - ExecWrapper__FPv() + 0x41
0x4021aeca - pthread
_detach() + 0x562
0x402fe3ca - __clone() + 0x3a
Anyone knows what this means and how this can be fixed?
(3,929 Views)
Raymond,
I would ask you to create a service request with National Instruments support here. I would also suggest it be an e-mail support request.
Randy Hoskin
Applications Engineering
(3,929 Views)
I am getting a similar error with LV70 Linux when
trying to start it in a WRQ window. Is there
an answer to the question?
- Received SIGSEGV
Attempt to reference address: 0x50f
Segmentation fault
thanks,
Dave
Fermilab
(3,929 Views)
