LabVIEW causing unstable readout
Hi all
I'm measuring the temperature of my sample using a Lakeshore 331S. Without LabVIEW the temp reading on the lakeshore is stable, and in agreement with pyrometer measurements. When I run the VI the output from the VI gives a very unstable temperature, fluctuating up to about 3 kelvin. The output on the Lakeshore also becomes unstable, but it seems to fluctuate even more (roughly 10 kelvin). When I stop running the VI the output on the lakeshore immediately stabilizes again.
I'm testing these connections out on the example VI's available from the Lakeshore 331S drivers found online (http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7094CC81B2146DD9E04400144FB7D2...). In particular I'm using the "application temperature controller" VI.  I'm running LabVIEW 2015 so I have 2015 driver.
I'm reading on a k-type thermocouple and my lakeshore is connected via an RSC-232c null modem cable
Thanks!
(1,389 Views)
Accepted by topic author JBrown97
Definitely seems like the settings are completely different when you run the VI vs when running standalone. Please verify if all the configurations match.
Santhosh
Soliton Technologies
(1,359 Views)
